timing belt change 1996 honda civic automatic
hi,
does anyone know of a good do it yourself tutorial on how to change the timing belt on a 1996 or equivalent honda civic? preferably with pictures and written for an idiot;) |
Hi Briceman124,
I just so happen to know of a relatively straight-forward tutorial written by an idiot for idiots :p 1) Note the radio security code and disconnect the negative battery cable. 2) Turn the crankshaft to align the timing belt matchmarks and set cylinder No. 1 to Top Dead Center (TDC) on the compression stroke. Once in this position, the engine must NOT be turned or disturbed. 3) Remove all necessary components to gain access to the cylinder head and timing belt covers. 4) Remove the cylinder head and timing belt covers: -Lower cover- a) Remove the accessory drive belts. b) Remove the crankshaft pulley. c) Remove the lower timing belt cover. -Upper cover- a) Remove the valve cover by performing the following:
http://www.hondapartsnow.com/diagram...elt-455415.png *Timing belt & cover diagram courtesy of hondapartsnow.com 5) There are 2 belts in this system; the one running to the camshaft pulley is the timing belt. The other, shorter one drives the balance shafts and is referred to as the balancer belt or timing balancer belt. Lock the timing belt adjuster in position by installing one of the lower timing belt cover bolts to the adjuster arm. 6) Loosen the timing belt and balancer shafts tensioner adjuster nut, but do not loosen the nut more than 1 turn. Push the tensioner for the balancer belt away from the belt to relieve the tension. Hold the tensioner and tighten the adjusting nut to hold the tensioner in place. 7) Carefully remove the balancer belt. Do not crimp or bend the belt; protect it from contact with oil or coolant. Slide the belt off the pulleys. 8) Remove the balancer belt drive sprocket from the crankshaft. 9) Loosen the lockbolt installed to the timing belt adjuster and loosen the adjusting nut. Push the timing belt adjuster to remove the tension on the timing belt, then tighten the adjuster nut. 10) Remove the timing belt. Do not crimp or bend the belt; protect it from contact with oil or coolant. Slide the belt off the pulleys. 11) If defective, remove the belt tensioners by performing the following:
Note: This is an excellent time to check or replace the water pump. Even if the timing belt is only being replaced as part of a good maintenance schedule, consider replacing the pump at the same time. -Installation- 1) If the water pump is to be replaced, install a new O-ring and make certain it is properly seated. Install the water pump and retaining bolts. Tighten the mounting bolts to 106 inch lbs. (12 Nm). 2) If the tensioners were removed, perform the following to install them:
The tensioner lever must be properly positioned on its pivot pin located on the oil pump. Be sure that the timing belt lever and tensioner moves freely and does not bind. 3) Install the lockbolt to the timing belt tensioner, do not tighten the lockbolt at this time. 4) Install the balancer belt pulley and adjuster lever. 5) Install the adjusting nut and the bolt to the balancer belt adjuster lever. Do not tighten the adjuster nut or bolt at this time. Be sure that the balancer lever and tensioner moves freely and does not bind. 6) Install the springs to the tensioners. 7) Move the timing belt tensioner its full deflection and tighten the lockbolt. 8) Move the balancer its full deflection and tighten the adjusting nut. 9) The crankshaft timing pointer must be perfectly aligned with the white mark on the flywheel or flex-plate; the camshaft pulley must be aligned so that the word UP is at the top of the pulley and the marks on the edge of the pulley are aligned with the surfaces of the head. 10) Install the timing belt over the pulleys and tensioners. 11) Loosen the bolt used to lock the timing belt tensioner. Loosen, then tighten the timing belt adjusting nut. 12) Turn the crankshaft counterclockwise until the cam pulley has moved 3 teeth; this creates tension on the timing belt. Loosen, then tighten the adjusting nut and tighten it to 33 ft. lbs. (45 Nm). Tighten the bolt used to lock the timing belt tensioner. 13) Realign the timing belt marks, then install the balancer belt drive sprocket on the crankshaft. 14) Align the front balancer pulley; the face of the front timing balancer pulley has a mark, which must be aligned with the notch on the oil pump body. This pulley is the one at 10 o'clock to the crank pulley when viewed from the pulley end. 15) Align the rear timing balancer pulley (2 o'clock from the crank pulley) using a 6 x 100mm bolt or rod. Mark the bolt or rod at a point 2.9 in. (74mm) from the end. Remove the bolt from the maintenance hole on the side of the block; insert the bolt or rod into the hole. Align the 2.9 in. (74mm) mark with the face of the hole. This pin will hold the shaft in place during installation. 16) Install the balancer belt. Once the belts are in place, be sure that all the engine alignment marks are still correct. If not, remove the belts, realign the engine and reinstall the belts. Once the belts are properly installed, slowly loosen the adjusting nut, allowing the tensioner to move against the belt. 17) Remove the pin from the maintenance hole and reinstall the bolt and washer. 18) Turn the crankshaft 1 full turn, then tighten the adjuster nut to 33 ft. lbs. (45 Nm). Remove the bolt used to lock the timing belt tensioner. 19) Install the lower cover, ensuring the rubber seals are in place. Install a new seal around the adjusting nut, DO NOT loosen the adjusting nut. 20) Install the key on the crankshaft and install the crankshaft pulley. Apply oil to the bolt threads and tighten it to 181 ft. lbs. (250 Nm). 21) Install the upper timing belt cover and all applicable components. When installing the side engine mount, tighten the bolt and nut attaching the mount to the engine to 40 ft. lbs. (55 Nm) and the through-bolt and nut to 47 ft. lbs. (65 Nm). 22) Connect the negative battery cable. http://content.chiltonsonline.com/co...s/91163p67.gif **Shown here: Matchmark the direction of rotation of the timing belt** Good luck man! :cool: |
I don't remember it's that complicated, and don't think 96 have a balancer shaft.
Ignore most of those instructions. Someone should write it up for the DIY forum here. The only thing that keeps it from being an easy DIY job is getting the crank pulley bolt out, because it needs to be very tight. But that is readily fixed by buying better tools.
Originally Posted by mk378
(Post 765770)
Yes I would appreciate a very detailed DIY with many pictures and no steps glossed over. Are most 6th generation honda civics done the same way? Yes I hear that the crank pully bolt is really a beetch....other than that it's easy? what i'm really worried about is getting something wrong and ruining my engine. If the timing belt had been changed before should the crank pully bolt be easier to remove? I was also thinking of buying a haynes manual but i don't know how useful that would be for this. |
"I was also thinking of buying a haynes manual but i don't know how useful that would be for this."
About as useful as thr steps stated above. |
Originally Posted by briceman124
(Post 765804)
My advice is if you need to tag every bolts nuts of where it come from when removed, then it is best to have someone assist you through the process that knows it. Would not recommend you to do it by yourself, but not saying you can't. My .02 cents. |
