Timing Belt and Gasket DIY
3 Attachment(s)
Just pick up most of the parts today, and waiting on the radiator hoses, reason for TB replacement is that coolant is leaking from the timing cover, hopefully the water pump is the culprit, plus it got oil residue everywhere. Don't remember if the engine compartment was ever clean since bought when new, LOL.
So the plan is change out TB, pump, tensioner, valve & pan gasket, dist o-ring, belts, rad hoses and trans fluid, etc.. The only thing done today was cleaning the engine compartment, will work on it tomorrow after work. Attachment 5596 Attachment 5597 After engine cleaned with GUNK.. a little better Attachment 5598 More to come..!! |
your engine bay is a crime scene!!
Car been with the family since the 90's, now my mom driving it. She been bringing it to her mechanic, until I recently found out how much they been charging her, and I was like.. DAYUM.. lol :(
doesn't look like her mechanic has been doing much,the radiator coolant looks to have never been changed
33 Attachment(s)
^ Ya.. is all rusted water, will change out another two time and see if get better within the next two weeks. Hope the car will last for another few years, then donation. BTW car has 220k miles so far.
But today finished TB, water pump, new drive belts, valve cover gasket and o-ring on distributor. Skip the oil pan gasket, cuz down pipe bolt was rusted and strip when i try to remove it. So process cont'd.. Attachment 5563 Attachment 5564 Remove valve cover Attachment 5565 Loosen power steering pump and set aside, and loosen alternator bracket and remove belts Attachment 5566 Remove steering pump bracket Attachment 5567 Attachment 5568 Attachment 5569 Turn timing to TDC (top dead center), all d-series have this marking, with 'UP' on top and two side mark (parallel mark) level with head, and pulley mark is line up with 'White' mark. Attachment 5570 Attachment 5571 Pulley bolt just laugh at this IR impact Attachment 5572 So bought out my BIG (3/4) gun, set air tank to about 125-130 psi.. BAAMM, came right out. :) Attachment 5573 Remove bottom cover Attachment 5574 Attachment 5575 Water seeping from this side weep hole Attachment 5576 Hook up my engine hanger, cuz don't want to use jack underneath, give me more room at bottom Attachment 5577 Remove motor mount Attachment 5578 Remove tensioner and water pump Attachment 5579 Attachment 5580 Attachment 5581 Reinstall tensioner and pump Attachment 5582 Then install timing belt, adjust tension, done.. reinstall Pull out dizzy for seal replacement and reinstall Attachment 5583 Attachment 5584 Got me wonder if the water pump was change during the previously timing belt replacement, timing belt looks good though, but pump is quite dirty, and whoever did the work didn't even change out the drive/alt belt.. it was all crack and some place missing chunks on those groove. UPDATE.. Well, the radiator hoses kit came in, order the Mishimoto set. Attachment 5585 Attachment 5586 And did a rear brake adjustment Attachment 5587 Attachment 5588 Attachment 5589 Put back the drum and using a flat head screwdriver to expand the tension on the adjuster until you can freely turn about 180 degree, you can feel the resistant, and remember to tap the drum side to side and top/bottom while adjusting. Then process of replacing the upper and lower radiator hoses and Thermostat. Removed the fan by disconnect the fan plug and two top bolt on fan housing Attachment 5590 Attachment 5591 Bottom hose retainer Attachment 5592 Top hoses thermostat ends, removed two bolts and thermostat is located inside. Attachment 5593 Attachment 5594 Attachment 5595 Reinstalled.. |
