TIMING HELP
Old Oct 22, 2006 | 03:52 PM
mschwantz's Avatar
Default TIMING HELP
JUST GOT MY MOTOR PUT BACK TOGETHER, THINK TIMING IS OFF, STALLS OUT AT HIGHER RPM. aNYWAY THE TIMING IS SUPPOSE TO BE 16 BTDC AT IDLE. BUT WHAT SHOULD IT BE AT LIKE 2500RPM, IT IS LIKE WAY OFF.
Old Oct 22, 2006 | 04:59 PM
AgentofDarkness's Avatar
Default RE: TIMING HELP
You only set the base timing (at idle) and the computer will adjust the timing for different RPMs.
Old Oct 25, 2006 | 01:20 PM
mschwantz's Avatar
my timing is right, but now at idle you can rev up just fine but put it in gear and rev up and it missed really bad, put new plugs on it, wires, fuel filter, could it be the fuel pump from sitting for 8 months?
Old Oct 25, 2006 | 02:12 PM
The fuel pump should not have been damaged by just sitting around for 6 months. However, if the gas in the gas tank has also been sitting around for 6 months, chances are that the gas is now stale. Try throwing some new fuel in there if its old.
Old Oct 25, 2006 | 02:55 PM
mschwantz's Avatar
tried new fuel filled it up with 93 octane, still does the same thing, at low rpms missed bad but at about 4000 starts to pick up a little better but still misses, no check engine lights or anything.
smackpower
Jan 13, 2024 01:42 AM
crxlvr
Jul 28, 2005 02:10 AM
Jas10hon
Jul 4, 2005 10:35 PM
forcefedcivic27
Sep 12, 2004 08:06 PM
alexander
May 19, 2004 11:07 AM
