TPS for 02' Civic Si K20A3
My TPS connector on my 02' Civic Si is cracked off. Since I see you can not buy just a TPS, and the whole TB is expensive I'm wondering if I can use a TPS off of another Honda. The TPS on a 2004 Accord looks exactly the same and the whole TB for an 04' Accord is only like $150. Does anyone know if an Accord TPS is the same / will work on my 02' Civic Si? Any thoughts on using another Honda model TPS other than the Accord or where I can get one?
Thanks! |
RE: TPS for 02' Civic Si K20A3
it might work, check the diameter too, the accord might be bigger cause its a 2.4 so you could get better throttle response
Do you need the TPS sensor or the connector? If you just need the connector, go to a junkyard where you take the parts off yourself and clip off the connector and a little bit of wire. Cut off the connector on your TPS sensor and solder in the connector you got from the junkyard.
