Is it a tranny problem or something else
I have a 1998 Honda civic When I start the car I have gears then after a couple of minutes I have nothing. In gear even though gears are not there engine idles down. Can anyone help with this issue Thanks Joel
Manual or automatic? If automatic have you checked the fluid level? (Automatics you pull the dipstick and check with the engine running). When "the gears are not there" and you try to make the car move, does the speedometer go up even though the car is not moving?
Originally Posted by mk378
(Post 764851)
Any ideas what this is? I was thinking my transmission cable broke but maybe that is just wishful (cheap) thinking. |
When the speedometer goes up but car doesn't move it is NOT a transmission problem. One of the CV axles has broken or pulled out of the transmission and disengaged, so the transmission is not connected to the wheels any more.
2004 civic lx auto trans slip
Hey I have an issue as well; I’ve got a 2004 civic Lx auto trans with 156,000 miles on it. When I start it up when cold in the morning I can drive for a couple minutes and then it goes to shift into a new gear and I lose all gears. I pull the car over, shut it off, start it back up and I can move for another minute or so before losing all gears. I have checked my inner cooler line to make sure that it’s not clogged(it has really good flow) I drained the fluid and added new so it is full and nothing has changed. Any suggestions? Closest auto shop is 45 minutes away and no way to get there.
| All times are GMT -8. The time now is 05:26 AM. |
