Trouble With MAP Sensor
I recently purchased a 97 Civic DX with the Check Engine Light on. The OBD II Code reader said it was because the Manifold Absolute Pressure (map) sensor was receiving high input - P0108. I replaced the sensor and I am still getting the code. The engine is running sluggish at low speeds. You can definately tell a loss of HP. I am wondering if anyone else has had this problem or might know what to look at. Thanks - Scooter
RE: Trouble With MAP Sensor
Check your Oxygen Senser which on your motor should go right into the bottom of your headers and is visible from the front of the car.
