Troubleshooting Common Problems
http://techautorepairs.com/images/th...ymptoms.th.gifMain relay symptoms are:
http://techautorepairs.com/images/th...ymptoms.th.gifIgnition switch symptoms are:
http://techautorepairs.com/images/th-noimage.th.gifBad ECU or ECU at fault:
http://techautorepairs.com/images/th-noimage.th.gifLow compression:
if you guys come up with any other good ideas that i cant think of at this moment let me know |
you have a chart thing to trouble shoot rpm gauges? i got a 93 civic and when i start the car my rpm needle goes way up to like 8k and bounces then goes to 0 and dont move till i rev it and it'll just jump to like 3k and drop to 0 again really fast. can you help?
you can fined answer [Right here on this forum! No need to go to outside links!]
(Don't post links like this. First, last, and only warning WCO). |
light surge
i have a 97 honda civic the lights surge on it i have replaced the ecu and the iat any sugesstions?
:confused: |
i have a 1994 civic dx just put a new starter on andstill wont start. i checked for voltage at the small cable on the starter when key is turned on and have none. Any suggestions where ui go from here.
this isnt a thread to post your problems, if you have a problem make your own threads
any body help about my honda d15b. my problem is the idle is getting drop to 200 or 300 when i turn on the head lights.
Originally Posted by maharba
(Post 769198)
I have a 91 civic dx I changed the fuel filter and when I start the car it loses power when I put it in reverse or drive what do I need to do now.
Why did you change your fuel filter? How are your spark plugs? worked on a 90's Chevy pick up about a month back in class that when you put it in gear the rpm would drop a lot. Replaced plugs wires ad fuel filter but didn't help. Found out the fuel pump was going out and didn't have enough flow.
