U0155
2007 Honda Civic just decided NOT to show travelling speed, hand brake light is on, engine check on ... ABS on ...
It runs normally , starts normally - but the dashboard is going nuts. Plugged in ODB scanner and read code U0155 - communication failure with "instrument module" . Proceeded with "recommended remedy " disconnect battery for 5 minutes. Same stuff - but the ODB scanner no longer works ! No ODB "experts " on web say - bad ground on "IPM" instrument panel module (?) But they do not say WHERE is this module? Can somebody give me a hit , from actual experience preferred? I can "guees" by myself : 1. where is this module 2. where do I find PROBABLE missing / intermittent ground connection for it ? This is most recent electrical problem with 100000 miles plus Honda. The gas gauge goes nuts intermittently missing last two or three "empty" segments . Somtimes it shows exact opposite tank "state" - the two or three segments on "full" scale are ON , while the rest of it - down to "empty:" - is dark! (No recall ?) After dealer changed the recalled passenger (?) side air bag - the radio intermittently works ONLY on RIGHT FRONT door - no place else ! My educated guess - I am missing ground - the question - WHERE? Live in Huston - no salt on roads here ! Please - serious replies only - " no check the brake fluid etc ".. Appreciate any help leading to resolution BY FIXI'N it myself. Cheers |
