urgent help needed...washed engine bay
i was being stupid and washed the engine bay
without covering intake, distributor, plug wires....
now when i start the car....its shaking bad
when i hit on gas.....but once the rpm go over 4000
the car starts to act as normal.....
wat did i *** up?
is it 'cause of moisture got into distributor?
i have removed the intake...there were some water in it
cleaned it, but havent put it back yet.....
plz help....wat can i do to make things back to normal
wat did i *** up?
RE: urgent help needed...washed engine bay
i am pretty sure you got some water ( moisture) inside the distr cap .remove cap, if you got access to compressed air blow it out , if not dry it out , put together and test drive car
ok so finally got things back to normal...
i checked distb cap and it was dry
so i dunno...where the water went
but i let the engine run for atleast 40 mins or
n car started to act normal again
although car kinda hesitates when in third gear
may be needs more dryin time...well hope so
other then that....everything is back to normal
Taasman
01-21-2009 03:12 PM
lordyrichie
12-04-2006 11:49 PM
