Valve Ping
Old Jun 5, 2005 | 01:56 PM
dooka4u4's Avatar
Default Valve Ping
Car: 1994 Honda Civic DX Sedan w/147k miles.
When cold and idleing the valves do not seem to ping... but as soon as I apply any gas whatsoever I get a valve pinging sound until the car warms up to normal operating temperature. No matter what the outside temperature is, it will do it for at least a minute or two after the car starts.
The car seems to idle fine and doesn't seem to idle surge or rev really high or rough, it is mostly smooth -- even when cold.
Once the car is warm, I have never heard the noise so far but I've only owned the car for about 3k miles. Any ideas? -Jim
Old Jun 6, 2005 | 02:05 AM
turbo y7's Avatar
Default RE: Valve Ping
Hi Jim,
Have you had the valves adjusted at all? This might help it out. It might not even be the valves, a tank of bad gas will also cause the engine to make "ping" sounds- Brock
Old Jun 6, 2005 | 08:48 PM
dooka4u4's Avatar
Pretty sure its not the gas... I buy from different places almost weekly. I run it down to about a 1/4 tank or so maybe a bit less each time...
As for having the valves adjusted, I may wait and take it into honda when I get the clutch, flywheel and thet bearings replaced + all new belts.
I'm personally thinking that the valves/springs are maybe worn out ... it does have 147k on it so maybe its time to find a newer d15b7 head for the car or get some new valve springs?
I hate to throw money around since its sparse for me and I don't really don't have an in-depth knowledge with cars.
Does anyone think picking up a low mileage head would be worth it? or should I just do the minimum to tie me over till I can get a b16 like I really want... I'd say the engine swap would be purchased and hopefully installed in a year or less from now.
Thank you for your advice,
Jim
cfrank9689
Dec 3, 2010 04:26 PM
corey
Oct 20, 2008 09:23 AM
Motor35
Oct 2, 2008 07:23 AM
civicpimpinsc
Nov 3, 2007 04:27 AM
jlh911
Jun 30, 2005 09:52 PM
