vtec?
Old Jul 1, 2005 | 01:10 AM
frizzlefry99's Avatar
Default vtec?
i read a post on here saying the a sohc with the plugs to the front of the valvecover is a vtec. is this true? my car has a sohc plugs to front but it doesn't say vtec anywhere can somone clarify
Old Jul 1, 2005 | 03:00 AM
ngoti 8tor's Avatar
Default RE: vtec?
What trim do you have?
Old Jul 1, 2005 | 10:05 AM
polo708's Avatar
Default RE: vtec?
If you cant tell by looks then can you tell by feel?
Starting at around 5500 rpm the cam profile will change over and you will get a jump in power. The exhaust note will change also. If you hear/feel that then you have vtec.
Old Jul 1, 2005 | 04:56 PM
glada96EX's Avatar
Default RE: vtec?
Also, isn't there something to do with the throttle body? I thought that if it is mounted horizontaly onto the intake mani then its V-TEC, and if its mounted virticaly then its not? Not sure if this is correct though.
Old Jul 1, 2005 | 05:15 PM
Street Sniper's Avatar
Default RE: vtec?
I have a V-tec and the throttle body is horizontal, the plugs are in the front, it doesn't say V-tec on the valve cover, and I CAN'T feel it when it "kicks" in.
Old Jul 1, 2005 | 05:28 PM
97CivicEX's Avatar
Default RE: vtec?
It's is very subtle on our SOHC engines. It is felt a lot more on DOHC's.
Old Jul 1, 2005 | 05:51 PM
Default RE: vtec?
That's what Sacicons keeps telling me.
Old Jul 1, 2005 | 06:27 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: vtec?
Sniper, you should be hearing the changeover by now...or you just didn't get adjusted to the thundermuff yet:-D
Old Jul 2, 2005 | 12:37 AM
sacicons's Avatar
Default RE: vtec?
with an intake he'll hear it more.
Old Jul 5, 2005 | 10:45 PM
JDMracer00's Avatar
Default RE: vtec?
just because the plugs are in the front does not mean it's got a VTEC. A DX civic doesn't have a vtec and the plugs are still in the front. Look at your engine code on the block. Also...what model civic do you have...? DX does not have a VTEC, EX does, and I believe the LX does...if not then the HX does
