HondaCivicForum.com
-   -   vtec not working? (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/vtec-not-working-84010/)
fo23rat Jul 10, 2010 08:30 PM
vtec not working?
ok so i was wondering i have a vtec motor and i was wonderin can yoou tell if your vtec isnt workin?
supersize Jul 10, 2010 09:01 PM
did you check your v-tak fluid? j.k. Do you have a check engine light? Low oil pressure/level, and failed vtec solenoid would be the 2 most common culprits. Another would be no speed signal going to the ECU, but I believe that would trigger a check engine light.
94civichatchback Jul 11, 2010 12:17 AM
if you have a cel the ecu goes into limp mode and will not engage vtec, also if you want to be positive vtec is kicking in you can wire a 12v light to the green wire going into the vtec solnoid, so when vtec is engaged the light will light up
fo23rat Jul 11, 2010 06:27 AM
a cel? whats that?
supersize Jul 11, 2010 06:30 AM
check engine light
NIKE H34D Jul 11, 2010 06:31 AM
Check
Engine
Light
http://jeremiahsimmons.files.wordpre...ck-engine1.jpg
What makes you think your VTEC isn't engaging?
maroon Jul 11, 2010 12:11 PM
nice
nice one CEL hahahahahah
fo23rat Jul 11, 2010 12:26 PM
Idk I feel like I don't feel like I'm gettin all the power I have.
mk378 Jul 11, 2010 02:02 PM
Make sure that your CEL has not been disabled. It should come on if you turn the key on but don't start the engine. The VTEC system will check itself ever time it engages. When you can wind the engine up over 6000 and the CEL doesn't come on you can assume it is working.
fo23rat Jul 11, 2010 07:59 PM
alright so does it matter if i have it in d4 or d3 or 2? and so when i get it to 6000 and the check engine light doesnt come on i have no problem with the vtec?
