Water or coolant
I've never seen clear coolant before either. It sounds like the seller may have just topped the reservoir up with water. Check the level in the rad (as AOL said), in case it's low, or has had the same thing done to it. Actually, if you can afford it, the best thing to do would be to get your cooling system flushed and a new thermostat in it. A lot of people neglect their cooling system and let it go a lot longer than they should (usually until something happens).
Yeah, when ya'll say "coolant" I assume you mean "anti-freeze" right? If you want to check the level before you flush and refill, they have these little testers that you suck up some of your coolant into and little floating ***** will tell you the ratio of anti-freeze to water.
paak
14
Nov 19, 2011 02:24 PM
reich17
14
May 20, 2011 12:34 PM
Garon
Sep 12, 2007 06:18 PM
etarted
Sep 2, 2004 11:47 PM
jjgarcia
Aug 22, 2004 07:39 PM
