Water pump and timing belt
I have a 95 Civic EX and it is leaking coolant out of the water pump.
The parts I have are: 1)Lower timing cover gasket 2)Upper right timing gasket 3)Upper left timing gasket 4)Valve cover gasket 5)Timing belt 6)Water pump 7)Water pump gasket What else do I need to buy? What other parts should I replace? How long does it take to do this job? |
RE: Water pump and timing belt
You only need the timing belt and water pump to fix that problem, but replacing the other stuff wont hurt anything. Time depends on tools and experience. If youve got good tools and know what youre doing, figure a few hours.......if not......maybe set aside a weekend lol.
Thanks for the info. I'llletyouknow howeverything turns out.Thanks again for the help.
