Weird noise with A/C on.
With the a/c on, and when i accelerate a weird noise happens. Coming from drivers side of the engine. Could this be one of the belts? When i let off the gas it usually goes away, if not i have to hit the AC button to off.
What do you guys think? |
RE: Weird noise with A/C on.
is it a loud squealing kinda noise that can be heard for like miles?? cuz mine does the same, it happens when the ac compressor kicks in. i believe its because of the belt.
is the belt something that it needs to be fixed ASAP?
thanks |
if part of the ac - not right away.
would be good idea to check all the belts. what shape are they in ? need to have 1/2 inch deflection at the middle of the longest dimension - unless specs give a different setting. |
| All times are GMT -8. The time now is 04:04 AM. |
