Wet Floor. Passenger Side 2008 LX???
It's been raining, ALOT but my car should still not leak... It's a 2008 so I'm guessing something just isn't lined up correctly? The floor is soaked on the passenger side and I was curious if any of you have had the same problem. Also, any idea which seal or area this could be coming from?
My little brother has a 97 EX and his does the same thing... We can't find the leaks... Thanks |
Do either of these cars have a sunroof?
If so could it be possible one of the drainage wells which are split or mis alligned, I beleive they run along the door panel and usually drain around the front wheel, (if you open your passenger side door I think its located on the sides where the hinges are?) if this was not alligned properly, this could possibly cause the problem? Only a thought, had a friend a civic eg who had this problem and this is what the cause was. |
Good call! My bro's does.. Mine does not though. I'll check his out. I totally forgot about that.
