what the****
Old Feb 14, 2008 | 07:22 AM
scottdh20's Avatar
Member
Default what the****
so i had a problem before with my car after the rebuild and you guys told me what was wrong, adjusting the throtle made a HUGE differance. as for the o2 sensor pain in my um yeah. so the cx wire harness is set up for a single wire o2 sensor but the d15b7 dx motor was set up for a 4 wire. my solution. swap harnesses. well all was going well a little over an hour i was nearing completion when i noticed a sensor but no wire to go to it (on firewall next to fuel filter). now the dx harness and motor are out of the same car. and it was there when i took out the motor. but it seems to have grown legs and walked away. i looked and searched.. nothing not even a stray wire that might indicate it breaking off (some of the wire seem pretty week oh yeah and it was about 4 degrees...literally) i got under the car, on top of it nowhere to be found. so i started it up no problem. but it idles high and there is ALOT of smoke comin out the exhaust. i checked the code...code 3 intake absolute pressure sensor or somthing. makes sence but how do i fix this.
any help would be GREATLY appreciated
Old Feb 14, 2008 | 08:13 AM
scottdh20's Avatar
Member
Default RE: what the****
anybody? nobody? i was thinking maybe just re wire it up. two of the wires are the same as the clip on the in. manny. so i was just thinkin maybe i could find the missing wire and just rewire i.i have the clip that snaps on to the sensor on the cx harness. would this work?
