93 1.7 vtec ecu code 14 IACV
Old 02-17-2014, 01:42 AM
jdub12212's Avatar
Default 93 1.7 vtec ecu code 14 IACV
Can anyone tell me what the voltage should be going to IACV? It has 5 volts, manual says battery voltage. does that mean it should be same voltage as battery? I took the intake off to fix some oil leaks and while I had it off I cleaned the intake. now have low idol. cleaned iacv and did not help low idol. I cant get it close to 700 rpm. sorry its a 1.6 vtec
Old 02-17-2014, 05:20 AM
You should have battery voltage on the yellow-black wire with the key on. This is supplied through the harness directly.
The ECU pulls the other wire toward ground when it needs to energize the valve coil and open the valve.
Also unplug the valve and check the coil resistance. I think it is supposed to be 10 ohms. Open circuit or a fault to ground means replace the valve.
Old 02-17-2014, 11:02 AM
jdub12212's Avatar
thanks for the info. I'm going to see if I can fix this without breaking something else. thanks again.
Old 02-17-2014, 01:29 PM
jdub12212's Avatar
its throwing code 10 IAT sensor, manual says resistance should be 1k to 4k. my multi-tester has 5 ohms settings, 2000k,200k,20k, 2000, 200. it doesn't show anything accept on 200, and then its 00.7. which setting should I use? voltage tests ok. any suggestion are welcome and appreciated.
Old 02-17-2014, 04:33 PM
OK we have:
5V at the IACV instead of 12V
No IACV operation
IAT and IACV sensor codes
This is easy. It appears that the plugs for the IAT and the IACV have been swapped and are plugged into the wrong devices. They're the same physical type of plug; it's not "idiot proof" like most cars.
I can't find my diagram right now but if you pull up a schematic (see the sticky list of manuals at the top of the forum) it will tell you which wire colors go to which sensor. You also have the purge control solenoid in the mix with the same kind of 2-wire plug on the back of the manifold.
jlor010
08-08-2010 06:21 AM
norbster86
07-30-2009 05:35 PM
jamisonh
02-21-2009 10:17 AM
trustdestruction
01-29-2009 12:02 PM
2000smazda
01-23-2008 04:32 PM
Quick Reply: 93 1.7 vtec ecu code 14 IACV
