94 civic ex speedometer issue... possible bad wire or connection?
Old 04-02-2012, 07:30 PM
wildchyld706's Avatar
Default 94 civic ex speedometer issue... possible bad wire or connection?
Having a lot of trouble finding the info to help me with this. Speedo works only when it feels like, jumps around but most of the time stays idle. Odometer does not work either. I judge speed using rp gauge. Changed vss, soldered speedo cluster connections, swapped clusters out 3 times, nothing works. I read somewhere about a ground being loose or a wire connection issue causing intermittent periods of it working, but I have been unable to find where someone can point me which wires could be faulty so they can be checked. Or if any other suggestions are out there. please help!
Old 04-03-2012, 04:11 AM
Check for damage or corrosion of the VSS plug.
mudhenFUF
01-16-2023 08:43 PM
inthezoneac
08-29-2008 12:50 PM
leeann1975
10-03-2007 09:10 AM
xsdudztx
08-14-2007 05:45 PM
skytanker2003
01-09-2006 11:45 AM
Quick Reply: 94 civic ex speedometer issue... possible bad wire or connection?
