where to get a knuckle?
Is there another name for the knuckle because I can't find it at autozone or oreilley's. Where is the best place to get one for 92 EX driver's side?
RE: where to get a knuckle?
best place: Honda dealer
But if I were you i'd head to the junkyard and pull a used one off a 92-95 civic. You can get it cheap and it'll work fine. |
are all of the models of 92-95 the same?
I did find on some junkyard search databases that they had "EX" and "except EX". Is the EX different? |
I think it has something to do with having ABS. If you have anti-lock brakes, you need the knuckle from an LX with ABS, or an EX with ABS. If you don't have ABS, you need one from a car without ABS. 92-95 will work.
I like the junkyard idea. Otherwise, here are some potential online OEM sources that will likely be cheaper than the dealership:
http://www.hondaautomotiveparts.com/ http://www.honda-tech.com/zerothread?id=2059889 |
