Why am I leaking?
Ihave a small fuel leak when car is started. The nut is screwed on as tight as it will go. I dont wanna strip it. I have taken it all apart and cleaned all of the connections, but it still leaks. What should i do? Do i have it to tight?
from the pic of were the leak is coming from that is a crush washer that you can replace for under a buck but on the other side of that banjo bolt you will need to replace that crushwasher as well because you are there and it will prevent any further leaking.
ic892003
20
Aug 21, 2008 03:40 PM
baker7598
Jun 21, 2005 11:47 PM
