Will these winter wheels fit
I own a 2009 Civic coupe with standard 16" wheels and 205/55R16 tires. I have been offered a set of winter tires and wheels from a 2008 Civic. The wheels are 15" and the tires 205/65R15. Will they fit? Unfortunately I can't try them on the car right now.
The answer depends on the hub and studs and brake assembly being the same on the coupe as on the sedan. Thanks for any help - M |
the brake clearance would be the deciding factor here. The lug patterns are the same (5x114.3) and the hub bore and offset should be the same since the wheels are coming off a similar Civic. If the part numbers from the 2008 civic caliper and the 2009 are the same (i have a feeling they are), you shouldn't have any problems.
