HondaCivicForum.com
-   -   window wont roll (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/window-wont-roll-32559/)
JMaN06 Nov 13, 2006 08:18 PM
window wont roll
hello, my driver side window does not roll up or down. i was told it needs a new window track....so if anyone has some info on what i need, or conformation on this diagnosis, its appreciated.
thanks!
windcalmer Nov 13, 2006 09:23 PM
RE: window wont roll
What year and all is your car? We need that to help you.
Year, trim, sedan or coupe, that kind of stuff.
JMaN06 Nov 13, 2006 09:30 PM
sorry. 94, coupe, manual windows,
windcalmer Nov 13, 2006 09:34 PM
Have you taken the door panel off? Is everything where it should be? Take off the passengers side panel and use it as a reference. Let us know.
If you can take a pic of the messed up one and post it here so we can see what is going on.
JMaN06 Nov 14, 2006 08:06 AM
i will do tonight. thanks.
i personally have not taken it off. i just bought the car from my friend to help him out in his debt, time of need. i am picking it up tonight. i will take off both panels and use as reference and take a pic. i will also be dynamatting them tonigh..which brings me to a next point. maybe my buddy is a bozo, it might be something simple i just havent looked yet...
ic892003 Nov 14, 2006 12:43 PM
it could be many things, window track ur window motor, possible anything, take a pic of inside the door panel and post, maybe someone can help u then
JMaN06 Nov 14, 2006 12:45 PM
wiill do. do the manual roll down windows have motors? or is it just a direct crank on a track?..
BrianT Nov 14, 2006 03:01 PM
it sounds like it's just off track, i would take it to an auto store and an epoxy (sp?), and glue it back on. if that doesn't work you will need to take it to a glass shop and have them fix it. you could also take it to the body shop.
JMaN06 Nov 14, 2006 03:06 PM
could you elaborate more on what could be done? i am pretty mechanically inclined and might be able to fix it myself. hopefully
JMaN06 Nov 14, 2006 03:10 PM
also, like i said. i was told its off the track. but im not to sure what that means or how to fix it...
