Windows off track
Old Oct 16, 2008 | 05:13 PM
AcivicKid's Avatar
Default Windows off track
hey, im having a few problems with my driver window it keeps comming off the track and then i gotta take the door apart again too fix it. I tryed lubeing it up and that worked for a wile. then the other day i was at tim hortons and it came off again but this time it was raining out. anyone have any ideas on what would be the best solution of perventing this from happing?
Old Oct 16, 2008 | 06:24 PM
gwl's Avatar
gwl
I use silicone spray to lube the tracks. If it still happens, the window track may be tweak.
Old Oct 17, 2008 | 06:11 AM
I had the same issue with my 98 Civic that I used to own. I probably took my window out about 30 + times to fix it before the window shattered into a million pieces. I would suggest cleaning out the inside of all the tracks. Also, make sure you are using the bolts on the bottom corner of your doors to tighten the window tracks into place properly. If you do not know where they are, I bet "RonJ" has a picture for you. This happened with my driver and passenger door window. I noticed that if I put the window all the way down, this would cause the window to come off track. Good Luck!
Old Oct 17, 2008 | 11:06 AM
Adjust the bottom of the tracks so they are close to the window (but not binding on it) when it is down, and make sure the bolts are secure. The bolt holes should be slotted so you can loosen the bolt and move the track.
Old Oct 17, 2008 | 11:42 AM
inthezoneac's Avatar
adjust the window balancer/alignment, whatever it's called. When you take apart the door panel it's located right in the middle of the door, a little to the left. Play with the window and that balancer to see what works. I had to keep mine down as far bottom as possible otherwise with it up the window will come out as it goes near the top.
and lubing the seals would help. I had to buy a nut for those bolts today because when mine gets to the top it'll drop a few centimeters so I'm going to secure the bolt(stripped metal in door where bolt stays, that's why it's loose)
reich17
14
May 20, 2011 12:34 PM
Feffman
Autocross and Road Course Racing
Jun 14, 2010 04:01 AM
wasabi27
May 21, 2008 09:43 PM
tlkolrod
Nov 11, 2006 12:22 AM
Tram
Jun 4, 2006 07:51 AM
