Windows wont go down!! (HELP)
Old Feb 8, 2009 | 03:08 PM
ghosttech's Avatar
Question Windows wont go down!! (HELP)
Ok so my Sat night i went out and while driving i wanted to lower my window and couldnt so i figured it was bc of the cold so i waited an hr and tried again nothing happened i checked the fuse and all are new and good i also took apart the door to see if something slipped and nothing has i also check the other door on my car to see if that window would go down and nothing happened i made sure that the lock wasnt on and also checked everything else that is on my door like power locks and speakers are working to make sure that its nothing tied into it i am confused on how this happened if anyone has any ideas or knows how to fix this issue please let me know bc in NY my tint is not legal and getting pulled over is not one thing i need oh by the way i have a Civic EX 94 coup
Old Feb 8, 2009 | 04:06 PM
Is the motor receiving battery voltage when the switch is turned ON? Does the motor run if you supply it with direct battery power?
Old Feb 8, 2009 | 05:59 PM
ghosttech's Avatar
how do i go about that??
Old Feb 8, 2009 | 06:11 PM
Access window motor and:
1) use voltmeter to test voltage at the motor connector when the switch is turned ON
2) run wires from battery to motor (reversing polarity reverses window direction -- up versus down).
Old Feb 9, 2009 | 09:24 AM
ghosttech's Avatar
ok i will try that later to see what happens besides that any other things i can try thanks for the help
Old Feb 9, 2009 | 06:51 PM
TheJGB3's Avatar
You probably need to lubricate the window tracks too.
Old Mar 23, 2009 | 07:23 AM
ghosttech's Avatar
ok so it turns out that the fuse box is bad in my car well not all but the one that sent the full power to the windows so i had to get a wire to jump it from one active connection to the bad to have the windows go down weird
billboboggems
Jun 11, 2011 10:17 AM
Juans_MX3
Apr 7, 2010 03:38 PM
d_reyes
Apr 19, 2008 10:23 PM
joespaghettio621
Mar 26, 2008 08:01 AM
Esquirrel
19
Aug 14, 2005 11:16 AM
