HondaCivicForum.com
-   -   wiper switch/control broken physically (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/wiper-switch-control-broken-physically-20031/)
jbum Apr 10, 2006 02:43 AM
The wiper control (the one to the right of the steering wheel column) seems to be physically broken.
Usually, you can pull it down and it will activate the wipers until you let go of the control lever.
You can also pull it towards you to activate the washer fluid. However, it seems the recoil
action is not there. Instead, the control lever just hangs and is loose. In fact, if I leave
it hanging, it activates the wipers and they don't go off until I prop the control lever
up with something.
Has anyone had experience with this? I'm thinking about taking apart the steering column
covers and taking off the wiper switch/control to see what's wrong. Any ideas/suggestions?
Thanks,
jbum
Stimpy Apr 10, 2006 04:24 PM
RE: wiper switch/control broken physically
What year car is it?
on my 95 CX you can drop the steering column onto the seat by removing the plastic and metal panels from below the steering wheel, then removing two bolts and two nuts holding the column in place. Then you can get a good look at that control.
I think you'd have the best luck just finding out how to replace it and nabbing one from a salvage yard.
btw.. watch the airbag if you start dinking in that area
jbum Apr 10, 2006 06:24 PM
ORIGINAL: Stimpy
it's a '93 dx. i'll only be taking off the cover and taking off the wiper control. should i be worried about the
airbag? i won't be touching anything else.
ef4life Apr 10, 2006 06:29 PM
yeah especially be careful with airbags. it only takes the tiniest amount of electric current to set one off.
prism Aug 10, 2013 09:17 AM
I have a 95 Civic DX with a parasitic battery draw so I end up with a dead battery. I suspect the wiper control arm may be the issue. The lever won't stay firmly in the up/off position since something broke on the inside a few years ago. They go on when I drive over bumps, RR tacks, etc. How would I test for that? I've been reading up on fuses, and how to test with a multimeter. Is the arm even a viable suspect?
