wont start after head gasket replacement.
hi . just got done replacing a head gasket. mechanical part was not difficult. car will not start. it cranks but no start. how do i check if i am getting spark. i don't suspect fuel problems since i did not have any before. thanks.
RE: wont start after head gasket replacement.
Welcome.
Did you check all of your connections? I forgot to reconnect my distributor last time I cahnged it and it took me 5 minutes to figure it out. |
yes i just got done checking connections. the car seems to want to start. it actually does with very low power. idles for a few seconds then it dies. does this mean i got a timing problem. thanks for your help.
Even if the timing was waaaay jacked up, it would still start, it would just run like ass. You may be off a tooth or two on your timing belt. That would suck.
if i was off on my timing belt is there a shortcut or just taking all apart and realign.
take it to someone that knows what they are doing before you really f up your motor!
your timing is probably off you do have to take the belt back off or move your plug wires up one or back one and try that
| All times are GMT -8. The time now is 11:30 PM. |
