D16z6 rebuild kit on y7 block
Old Aug 4, 2019 | 07:13 PM
Chinowpr15's Avatar
Default D16z6 rebuild kit on y7 block
Hey i will be doing a mini me swap and i am trying to figure out if i can use a Z6 rebuld kit on my y7 block since i will have the z6 head and valve cover or should i do a y7 kit even tho i will have the z6 head?
Im kinda new to this
Old Aug 5, 2019 | 04:15 AM
StifflersMom's Avatar
Cat Fuсker
Are you talking about a master rebuild kit? If yes - get the Z6 and buy whatever doesn't fit separately, provided that you already have the z6 head.
Old Aug 5, 2019 | 07:42 AM
Chinowpr15's Avatar
I might sound dumb but i was just going to get a basic rebuild kit lol is there a diff with the master rebuild ?
Old Aug 5, 2019 | 08:40 AM
drakon543's Avatar
pay attention to whats included in the rebuild kit your looking to buy and make sure you know what parts you want in a kit. basic kits are just that just a freshen up kit basically. master kits will have more parts included in the kit along with the same parts in the basic kit. just think basic kit = freshen up master kit = overhaul. also there are plenty of brand kits out there and they done all include the same thing.
Old Aug 5, 2019 | 08:43 AM
Chinowpr15's Avatar
yea my engine has 198k so i wanted to rebuild it so itll last me since it will be my daily i wont be doing much racing its more for show and its cheaper I guess, but would you recommend a master kit over the basic for long haul driving ?
Old Aug 5, 2019 | 10:12 AM
drakon543's Avatar
your big items will be valve seals and cam and rod bearings. piston rings are fairly important also but they usually come in both kits i believe. your other big item is timing belt and tensioner, water pump and oil pump. timing kits are generally sold separately but whatever kits includes what i mentioned.
Old Aug 5, 2019 | 01:35 PM
Chinowpr15's Avatar
Ok awesome yea the rebuild kit im getting has all that except the cam and rod bearings i think.
another question can i use a Y8 trans on the y7 block with the z6 head ? Im having alot of trouble trying to find a z6 trans and for the y8 ive found like 3
Old Aug 5, 2019 | 05:41 PM
Cat Fuсker
Yes you can use a y8 trans, but it's been so many years for me I don't remember if the speed sensor matches. Probably does, if not - use a Z6 one.
Before you go and order stuff how about actually taking the block apart and taking a bunch of measurements to see if all you need is a re-hone or possibly a bore out with the next size up pistons. Make sure you check the cylinders for being out of round on top and about mid-way down. All of the specs are found in any good manual for your car.
Old Aug 5, 2019 | 05:58 PM
Chinowpr15's Avatar
Awesome thank you so much brother and i will be taking the motor out this week hopefully wednesday and ill start taking everything apart and will do all the measurements
Old Aug 5, 2019 | 05:59 PM
Cat Fuсker
Also make sure the crank is within spec. It is possible that you may need a crank grind and one size up mains and rod bearings.
