I NEED HELP. 1995 honda civic 4d EX
Okay. My car isnt super modified but it had a fair amount of work done to it. Heres the rundown of whats been done to my car. I have a 1995 4dr Ex. It has the basics headers(DC sport), Intake(matrix), cat back exahust(Tannabe), Adjustible cam gear(Skunk2), vtec controller(Apexi), Tien 16 way adjustible street damper and slotted roters. Street fighter 2 body kit the back door handles have been shaved off and the car has been paintet Sundance Orange. Thats my car I will enclose pictures tomorrow.
:(:(:( The problem I have is while I was driving down the street I heard a wierd noise not knowing what it was I looked in all my mirrors. Then in my drivers side mirror i see somthing rolling off across the street. My car then starts kinda stuttering. So I pull it over and open the hood to see all my drive blets shreded. When I try to find the cause of the problem I find out the Harmonic Balancer came off. The bolt that hold the Harmonice Balancer in place broke off in side of the Crank shaft. The bolt has been removed but I'm not sure what I should do now it will cost me 450-500 to fix this problem and have my D16 working again. Or should I just try putting in a B16 in it. If I which one do i need b16a1 or 2 1 has a cable cluch right and 2 hydrolic cluch. Im not sure which one I'm supposto use? And does anyone here live in Virgina and if they do do they know a good place to get the swap done? I'll have about 3000-3500 dollars will that be enough to get the swap done? I would really appreciate the help with this problem. Thank you in advance. I can't spell to well either. thanks. |
RE: I NEED HELP. 1995 honda civic 4d EX
Hmmm. try here for a motor. I wouldnt know where in virginia to go. Sorry.
im pretty sure that you will need the b16 with hydraulic clutch as my friend has a 95 ex and his is hydraulic he also is looking into a b16 conversion and as yours is a D series you will need custom engine mounts but after that the conversion is pretty easy but you may have to get an auto electrician to wire it up. if you do everthing else yourself it would probably only cost you 1500 to 2000. hope that helps.
[sm=jawdrop.gif]I thought I was the only one who has crap like this happening. did it damage anything as it came off? and you got the bolt out? how in the hell is it going to cost 500 bucks? i could fix that for under 100.
The reason it's gonna cost 400-500 is cause the work so far to take the bolt out. There is a hair line crack in the key hole the guy said he can brase it or somting, but there is the chance that it will go again. I tried to price a b16 swap there charging around 4400-5500 dollars so im not gonna do that. I did find a company to put the same d16 in it for about 1800, and he will put all the preformance mods back on the new engine for me. Also he said they give a 1 year 12000 mile warrenty on it. So that is what i think I'm gonna do. Seems like to much money to get the b16 in it, i asked how much if i had the engine they would charge 2200-3200 about. So i say screw it SOHC fo life. i apreciate the info from you guys, and here are pictures of my car what do you think?
[IMG]local://upfiles/7830/9E085D202E1745C7ABC2134478E22CE5.jpg[/IMG] [IMG]local://upfiles/7830/CD8E5194C24F41C8993F878884BF065D.jpg[/IMG] |
