1g dsm smic in EG
How easy is the mounting for this beast?? And any available piping kits?
RE: 1g dsm smic in EG
i wouldn't call it a beast by any means. honestly ifi was going smic... i'd go w/ the Supra SMIC, it will flow a lot better and support 400hp no problem.
you usually have to get a bit creative with the piping, either hack sawing/cutting, and then sometimes welding it, other times (easier a bit, can do this just with sockets/wrenches/screwdrivers) just getting a nice get of couplers and T-bolts (better than those dinky little clamps) will do.
any reason your going SMIC over FMIC? You just get your hands on one? |
ORIGINAL: FlipHKD720 you usually have to get a bit creative with the piping, either hack sawing/cutting, and then sometimes welding it, other times (easier a bit, can do this just with sockets/wrenches/screwdrivers) just getting a nice get of couplers and T-bolts (better than those dinky little clamps) will do. any reason your going SMIC over FMIC? You just get your hands on one? |
you can buy custom piping kits off ebay for like $100, i found one with t-bolts included as well. Yea $25 is cheap, btu IMO i dont think FMIC is too fancy. Its a pretty basic setup, especially becasue of the way you usally run charge piping in 5th and 6th gen Civics.
it also depends on what kind of turbo you are going to e running. if you are planning on running a 16g or larger, i'd suggest going with a smaller fmic rather than a dsm smic.the smic will start heat soaking BADDD anything over 250whp.
I don't understand why people use SMICs when the only thing they are good for is heating up your intake charge.
agreed. the only instance where a DSM smic would do ANY good is for a teeny tiny turbo pushing no more than 6-8lbs. anything about 10lbs and it's going to soak. you can snatch a full fmic w/ piping on Ebay for 200-300. granted it's not the best material but a small fmic would lower temps 30-40 degrees.
ebay intercooler: $100
2.5" piping, couplers, and T-Bolts on eBay: $100 |
I suggest getting quality parts rather than cheap ebay stuff, unless you wanna join the Blown Motor Club. What are your power goals?
________ yourSweetPie |
