255 fuel pump
Old Jan 10, 2007 | 04:27 PM
mugen23's Avatar
Default 255 fuel pump
for a turbo,,,,, i bought a chipped ecu with 450 injectors will i need to buy a bigger fuel pump for my car or not
Old Jan 10, 2007 | 06:13 PM
red2000Si's Avatar
Default RE: 255 fuel pump
I have read from many reliable sources that a bigger fuel pump is not needed unless you plan to make 275-300 whp. I would save your money and use it elsewhere unless you are planning to make somepretty huge power.
Old Jan 10, 2007 | 07:26 PM
sacicons's Avatar
my NA gsr was leaning out on the stock pump at 157 whp. i put in the 255 Walbro, and it is fine now at over 170whp. overkill actually, but now im ready for whatever i decide to do.
Old Jan 11, 2007 | 08:56 AM
what motor and turbo? Aren't you planning on running like an 18g on a bseries?
Old Jan 11, 2007 | 10:47 AM
red2000Si's Avatar
No thats me and Im staying with the stock pump, at least for now.
Old Jan 11, 2007 | 11:19 AM
finalimpact's Avatar
a 255 might be a little overkill for your set up depending on your goals. however a new pump is a good precaution to take for a better margin of saftey in the long run. imo the $100 is well spent for saftey issues.
Old Jan 11, 2007 | 12:22 PM
ORIGINAL: red2000Si
Oh yeah that's right. You may want to upgrade tot he 255, you're going to be damn near maxxed with that turbo
Old Jan 11, 2007 | 06:42 PM
sacicons's Avatar
ORIGINAL: finalimpact
a fuel pump is something thats ok to go a little overkill on. only real downside is a little more noise, but not enough to be annoying.
Old Jan 11, 2007 | 07:07 PM
Kedawei's Avatar
Get ze pump.
Old Jan 11, 2007 | 08:26 PM
ORIGINAL: sacicons
i only find it annoying while its priming.....
