B16a max hp limit on stock?
Old Nov 27, 2006 | 08:47 PM
Carlz0r's Avatar
Default B16a max hp limit on stock?
Sorry if this has been discussed to death. I spent about half an hour searching and couldn't find any substantial information. I've got a free Zex wet kit, and I just bought my Civic. It has a b16a swapped into it with approximately 80,000km on it. What size shot should I use max? I was thinking a 35 shot, but I'd rather get confirmation first. Thanks.
Old Nov 27, 2006 | 10:53 PM
SovXietday's Avatar
Default RE: B16a max hp limit on stock?
50shot would be fine.
Old Nov 27, 2006 | 11:44 PM
Pete's Avatar
Dont just hook up a 50 shot and start spraying. Youll want some bigger injectors, a bigger fuel pump and a dyno tune. Those things arent necessary, but they will prolong the life of the motor by a LOT
Old Nov 27, 2006 | 11:58 PM
sacicons's Avatar
at the least, get some colder spark plugs and set the ignition timing to 14 degrees BTDC. then a 50 shot will be fine.
Old Nov 28, 2006 | 12:30 AM
Carlz0r's Avatar
From what I was told, it comes with the nozzle for a 35 shot. I probably wont install it until I've got the money for new injectors and fuel pump. Thanks for the quick responses, I appreciate it.
Old Nov 28, 2006 | 11:47 AM
Remmy's Avatar
I would at elast go RC 440 injectors.
Old Nov 28, 2006 | 06:13 PM
MY99SI's Avatar
we had a hatch with an ls swap done on a 75 shot. these motors can handle some power ... he did it on the stock injectors with a vafc hack. it ran a 13.01 when it went at the track...
that was 15 bottles at a 75 shot..
MTC
Dec 20, 2008 06:59 PM
tombakers
May 4, 2008 05:23 AM
o320
Apr 12, 2008 02:59 PM
