cast or tubular mani?
Old Jul 30, 2008 | 05:00 AM
Mistaashby12's Avatar
Default cast or tubular mani?
about 75% of ppl I talk to say tubular.
but the few others say cast because of its ability to retain heat better and some how that helps spool faster not much at all but just a little.
Old Jul 30, 2008 | 05:22 AM
GReddy_Civic's Avatar
Snail'n Admin
Default RE: cast or tubular mani?
Not to be a *****, but you need to do more research. You arent ready for boost and its a bit old to see thread after thread
Old Jul 30, 2008 | 05:23 AM
I have Ive read and read but never really fond anything real perticular. could you point me in the right direction?
Old Jul 30, 2008 | 05:27 AM
and I cannot tell when a mani is going to allow a/c or not.
I do not want a/c. because what I have read allows for a less restrictive path of air flow..?
Old Jul 30, 2008 | 05:31 AM
Snail'n Admin
If you want to keep A/C, youll really limit your choices, most of which are cast log manifolds. http://www.honda-tech.com/zerothread/2152865
Old Jul 30, 2008 | 05:45 AM
Live_4it's Avatar
cast manifolds are usually much easier to put in cause they are smaller and the turbo doesn't hang too low or stick out needing the a/c taken out or other things relocated. But the tubular designs have much better flow and good for better power numbers.
Old Jul 30, 2008 | 05:50 AM
ok I read that forum. but all I find is contradicting numbers and opinions. I did learn with my current goals I do NOT want a top mount LOL thats about all I really got from that whole thing. just because once someone said something that made sense someone else would say another. ect.
and when they refer to log that is a cast I assume that just runs 4 into1?
Old Jul 30, 2008 | 06:20 AM
Snail'n Admin
Cast are usually the cheapest but do hold up well with boost. They are easier to work on due to size, but offer the worst flow. Ramhorn or minos work pretty well
Old Jul 30, 2008 | 06:29 AM
best I can tell the mini ramhorn is the way to go. or the best cast I can find. for what Im doing. Im buying a garrett t3t4 50 trim .63ar and
goal of 350hp
what would you do. I want the most efficent powerband
Old Jul 30, 2008 | 06:37 AM
Snail'n Admin
ramhorn probably
