Chipped p28
Old Feb 13, 2007 | 07:18 PM
dfdon's Avatar
Default Chipped p28
wanna order my chipped ecu from stealthmode (the oil line guys) and the say they need the file so they can chip an ecu with a basemap for me....help me out
Old Feb 13, 2007 | 08:57 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
Default RE: Chipped p28
thats weird because i never had to give them the basemap, i just had my tuner burn a chip for me. do you have a tuner yet or not?
Old Feb 14, 2007 | 09:32 AM
Just give them a detailed list of your setup, they should be able to create a basemap from there. Your motor will sound/run like **** on it, but it'll get you to your tuner's place at least..
Old Feb 14, 2007 | 10:24 AM
SovXietday's Avatar
What's your setup going to be?
Engine:
Turbo:
What PSI:
Injector Size:
Fuel Pump:
Octane:
Old Feb 14, 2007 | 08:08 PM
dfdon's Avatar
b16a2
garrett t3/to4b
15 tops
450
walbro 255
93
Old Feb 14, 2007 | 08:46 PM
SovXietday's Avatar
Ok, better question, what MAP sensor do you have on there?
If it's stock, keep it under 12.
Old Feb 14, 2007 | 08:49 PM
dfdon's Avatar
ight man thanks i knew it was wither 12 or 15 thanks
Old Feb 14, 2007 | 09:10 PM
ORIGINAL: dfdon
b16a2
garrett t3/to4b
15 tops
450
walbro 255
93
i would email that to stealth and let them know thats your specs you will be running
Old Feb 14, 2007 | 09:18 PM
SovXietday's Avatar
http://users.rcn.com/dwilz/dfdonbasemap.bin
That should work, give me a few minutes I may try to touch it up a bit.
Old Feb 14, 2007 | 09:37 PM
SovXietday's Avatar
Ok, I updated it slightly, unfortunately basemaps are hit or miss, sometimes they start and idle and other times they don't.[&:]
Just remember that this is a BASEMAP! Make sure that if/when the car starts, let it warm up to operating temperature and then drive it to your tuner without going much past 5* vacuum. I tried setting it as far on the conservative side as possible but there isn't really much I can do as far as fuel without you driving and me watching a wideband. Timing should be plenty conservative.
