HondaCivicForum.com
-   Nitrous, Super Chargers, & Turbos (https://www.hondacivicforum.com/forum/nitrous-super-chargers-turbos-13/)
-   -   D16 question (https://www.hondacivicforum.com/forum/nitrous-super-chargers-turbos-13/d16-question-74621/)
CivicJunkie Apr 7, 2009 09:12 AM
D16 question
Is a Garrett T25 ball bearing turbo compatible with a d16 engine?
V8DIET Apr 7, 2009 09:53 AM
Really it you had the time and money you could put any turbo you wanted on the car. Weather the T25 is appropriate for your setup will depend on these things..... What psi is that turbo designed to run? Is your motor built at all or is it stock. What other mods are done to the car?
bakertime Apr 7, 2009 04:22 PM
You can put any turbo on a D16 with the right manifold. Before you get too far into it though, you should look at what different turbo sizes mean, and other people's setups. A small turbo will spool faster, but run out of steam in the high RPMs. The opposite is also true, however there are a number of combination in between that you'll need to research to find what fits your needs and meets your power goals.
Good luck!
GReddy_Civic Apr 7, 2009 07:01 PM
Decide your power goals, budget and how you want to drive the car.
CivicJunkie Apr 8, 2009 02:34 PM
Thanks guys. I'm trying to get about 200 whp out of it, so like 10-15 psi.
I've got new pistons and rods because those are usually the first things to blow, my sleeves are in pretty good shape. Ive got an exhaust, cold air intake, stage 2 clutch.
trustdestruction Apr 8, 2009 04:21 PM
do your rod bolts too (use ARP)
also, get some ARP head studs, to prevent head lift
CivicJunkie Apr 9, 2009 03:45 PM
yeah that sound like a good idea. ill check it out. thanks
