d16 turbo
Old May 11, 2008 | 06:24 PM
arust45's Avatar
Default RE: d16 turbo
My compression was within 5% and optimal leakdown, but my head lifted with a t3/t4 on 7lbs. Blown head gasket can lead to big problems, better to be safe than sorry.Spend the extra 120 dude. The t3 turbo I have is a perfect fit for our sized motors, even though I loved my t3/t4, either of the two is a good choice.
________
New condo pattaya
Old May 12, 2008 | 06:01 PM
SovXietday's Avatar
ORIGINAL: arust45
Stock Y8?
Whoever tuned your car put a Z6 timing map on it. Happens all the time. Too much timing will cause headlift in the smallbore Dseries engines, really doesn't have anything to do with the psi.
OP, if you're going to stay with the stock engine, however many PSI it will take to make ~215ish mark would be where I would stay with. Correct tuning needed obviously.
T25 you will probably need 10-12psi to get to that mark. PSI really isn't what blows engines, bad tuning and detonation does.
fastrecklessracer
Dec 31, 2007 02:44 PM
ballplaya4eva07
24
Jun 16, 2005 07:15 PM
ballplaya4eva07
Dec 12, 2004 07:41 PM
iceman56
Jul 1, 2004 08:46 AM
