d16Z6 turbo
Well guys, I am planning on going turbo on my stock d16z6 (pushing 108K). My question is really how much boost can the stock internals handle? I am planning on doing a remote (probably after-cat) turbocharger. And another question would be whether I need big injectors, high volume fule pump, etc., if I'm not pushing much boost? What would you recommend? It's a tight-budget project that I'll tackle very soon.
ORIGINAL: but why after cat??
and to go N/A with this setup I'll just have to put a short piece of pipe in place of it and be done in less than 30 minutes.
you dont sound like a guy i would want to be a friend with if you wanna make them think they are racin a n/a car and then you secretly have a turbo in. better not be racin for $$$$ if ur gonna pull somethin like that
ORIGINAL: green98lxsedan
Well first of all, and after-cat turbo is a unique idea, but you should take a few things into consideration:
1) How in the world would you run the piping to your intercooler and filter? Those pipes are thick (much thiker than the exhaust pipes)
2) CAT produces a lot of backpressure, therefore restricting the airflow. I don't think you'll get enough air in the turbine to produce desired results.
I suggest to sell your header and go for a standard turbo setup. Your friends will probably hear your turbo spooling and blow off. Another thing is that there is no way around plumbing. When you pop the hood, your friends will see the pipes going from the turbo (the intake pipe will be much bigger than the OEM one. Another issue is the intercooler (you may get away without one if you don't run above 6psi, but I don't think it's a very good idea. Also, if you got a lowered car, you could damage the turbine if you hit a pothole or something. Therefore, if anything, try putting a turbo somewhere before the cat
