Extra injector?
My car (supercharged) has an extra injector and like sacicons said... its very common. It would be easier to just get larger injectors though. As far as the fuel pump goes, Kenne Belle make a boost-a-pump which basically increases the flow rate of your stock fuel pump. Look into that if you're serious about it.
If you compare the performance of the same engine with carb vs EFI you will get more hp and better gas mileage on the EFI
though tuning an engine like that with carbs becomes a major ordeal when you start changing elevations. when i moved to Sacramento (about 50 ft in elevation) from up near Reno (about 4-5k) my buddy with an old carbed dodge moved here with me. his car ran like crap for the entire time he lived here. had NO power, and got HORRIBLE mileage. and i happily drove around in my EFI civic, and he wanted to get a crx. on the street, EFI all the way. on the track, whatever you are more comfortable with.
yeah thats another thing carbs arent good for, altitude changes. i personally like carbs and efi, i actually want to try a carb set up on my hatch. until i can afford to, ill try ITB's for now.
nightrider46
Mar 31, 2008 04:59 PM
greenzcmachine
13
Mar 22, 2006 07:05 PM
joeymr21
Jan 24, 2006 08:20 PM
