Fuel and ignition management
Old Nov 18, 2005 | 09:19 PM
91crx_87's Avatar
Default Fuel and ignition management
I am planning on putting a bolt on turbo onto my b18a1. I was just curious how important it would be that i upgrade my ignition and fuel management system.
Old Nov 20, 2005 | 01:14 AM
riceburner700's Avatar
Default RE: Fuel and ignition management
how much boost?
you will need at least a fmu or e-management
and some bigger injectors like 310cc wouldnt hurt either
Old Nov 20, 2005 | 01:15 AM
and you might need to mess around with the timing a little bit depending on how much boost also
Old Nov 20, 2005 | 09:35 AM
BallardCivic's Avatar
With lowboost, youll probably be alright without doing a whole lot, but if you want a lot of boost, some 310s are good, and AEM makes good fuel mangement systems.
Old Nov 20, 2005 | 01:12 PM
Street Sniper's Avatar
Your ignition will be fine, but at the very least you will need an FMU or a regulator and larger injectors. The FMU is the cheapest way to go but also allows for the least amount of tuning.
Old Nov 20, 2005 | 01:27 PM
91crx_87's Avatar
I'm thinking of running at about 8 lbs. of boost.
Old Nov 20, 2005 | 02:22 PM
Pete's Avatar
Well you definetly need to get some colder plugs. (check out the NGK bcpr7es-11). Fuel management is KEY in making power. I am currently running GReddys blue box. its not bad, but its a base-tune and i wont have it for long. I would upgrade spark plugs too. You get get some DSM plugs pretty cheap on ebay, or spend a few bucks on the RC ones. For fuel management the choices are endless.
You can get your ECU chipped for UBERDATA (see if u have any dyno tuners around you)
You can get some HONDATA and get that tuned.
You can get GReddy EMANAGE and get that tuned.
You can get an FMU (like a vortec 12:1 or whatever) and an adjustable Fuel Pressure Regulator.
You can spend big bucks and get AEM EMS (stand alone engine management)
It all depends on what youre willing to spend.
Marty
Dec 9, 2005 02:11 PM
Marty
Dec 7, 2005 01:56 AM
smokingemcee
15
Aug 5, 2005 08:33 PM
97civicturbo
Apr 7, 2005 11:53 AM
Blackhatch124
Mar 19, 2005 02:24 PM
