greddy turbo charger kit
well depending on the turbo kit, you dont need to build your motor, as alot of them are made for stock applications on a lower boost, there is a good write-up in the search button there, just type turbo and find forty04 writeup on what u need to build a setup. Very good thread
i did a little bit of searching and reading and i think i figured it out, BUT i'm still probably wrong lol
ok so in order for my car to be tuned i need to get a chip for my ecu, i take that to the tuner,
they program it and put it in and do whatever else they have to do,
then when the the motor and turbo get put in the car i take it to the tuner and they tune it.
is this right or am i still stupid?
thanks for being so patient with me
ORIGINAL: RCJr9186
they can't tune a stock ECU. so you will have to either have the ECU Chipped, get an aftermarket piggy back system such as Hondata, Chrome, Greddy Emanage, etc etc., or you could even tune with something as small as a SAFCII but the car MUST be tuned once you put the turbo kit on, otherwise you may end up blowing up ur engine and then you would have wasted all that time and money saving up for the turbo kit w/ no car to drive.
i try to explain things in a simple to understand manner.
Silver - we all started some time or another so we understand you are new. basically it all depends on what kind of power you are trying to make. if you just want some extra pep, than piece together a cheap kit, get a VAFC controller, tune it to a safe A/F ratio (or have somebody else do it, whatever) and you'll be good.
most of the time people make this molehill and turn it into a mountain. it's all dependant on your goals. if you are wanting like a 600whp beast than i'd never recomend a simple SAFC/VAFC. it would definatly have to be a piggyback and acutally you may get ur money's worth by going stand alone.
IMO here's how i look at it.
- 350whp = SAFC/VAFC is fine
350 - 600whp = piggy back/chipped ecu
600+ = stand alone for sure!
Im looking for about 180hp(if possible) on my d15b7. I want use a low safe amount of boost, I think I will look into the hondata f200 + boost I think is what it is, not completely sure but I did see it on option jdm or something
ok i'm not really sure what you are talking about,lol, but i'm looking to get between 200-250 whp, so what do i need for that and i'm not going to tune it myself because i don't want to mess anything up
carid
Dec 4, 2014 12:59 AM
javierdagreat
22
May 19, 2005 11:29 AM
