Looking To Turbo
Old Aug 2, 2007 | 04:51 PM
CivicCrazy88's Avatar
Default Looking To Turbo
I have a 2001 Honda Civic Ex with complete stock motor and I want to put a little more power so I thought Turbo it.
What kind of turbo can my engine support here are the Motor specs
1,668 cc 1.7 liters 4 in-line front engine with 75 mm bore, 94.4 mm stroke, 9.9 compression ratio, overhead cam, variable valve timing/camshaft and four valves per cylinder
Old Aug 2, 2007 | 05:19 PM
didder's Avatar
Default RE: Looking To Turbo
dont turbo a d17 unless you have a ton of money, a ton of patience, and a ton of experiance with cars.
hardest motor to turbo is a d17 because of the fuel mapping.
just put intake / header / exhaustand go naturally aspirated, youll be plenty fine with that and you wont have extreme headaches
Old Aug 2, 2007 | 05:35 PM
Yea Thanks I figured Id ask I have a full Catback exhast and a coolair intake
Old Aug 2, 2007 | 06:55 PM
johnny's Avatar
If your a boost junky, go get yourself a EG hatch (92-95') and boost he D16z6 engine that comes in it.
Old Aug 2, 2007 | 07:03 PM
Mr Mobsta Man's Avatar
Best way to gain a lot of power in a car with a d17 would be to swap it out with a k20.
Old Aug 4, 2007 | 07:50 PM
K20 explain more about this motor and what am i looking at price wise?
Old Aug 4, 2007 | 08:16 PM
With your car I'm not sure how much it would cost to acually swap the engine but the k20z3 from the new civic si'shave 197hp and they are about $5-6k with a manual transmission iirc. I'm sure someone elsehere can clear it up.
Old Aug 4, 2007 | 08:30 PM
my05civic's Avatar
k20a2
8-10K depending on how much you get the parts for and how much you do yourself
SovXietday
21
Jul 26, 2011 03:40 PM
addiction2bass
Feb 4, 2008 06:43 PM
dblclutchin
Feb 9, 2007 12:11 AM
