New power adder
Just added a 50 shot to my 95 civic with a supercharged b18c1. The car is still untuned since the motor build and sc port job. Wanting some input on what you guys think my car will put down on the dyno. Its got a built bottom end, stock compression, 12lbs pulley, intake, full exhaust, 440cc injectors....thats the basics. Tuning with Hondata s200. Im taking it to the tuner this saturday, Ill post up how close your educated guesses were!
not if its a dry shot those 440cc will be way to small. but i suppose 300 with the spray way to hard to tell though and those injectors are really looking like a weak point in your build whats your fuel pressure is it stock? I doubt those will flow enough fuel without being over their duty cycle
Well depends how much air that supercharger is really pulling in and how much horsepower you want but i did a quick basemap on crome and it looks like 525cc at least maybe a bit higher, i would do even higher because superchargers make alot of heat but im sure your tuner would recommend the correct size check with him, I mean if you only want about 250-280whp, 440cc should do just fine again it depends on if it is a dry or wet shot because a wet shot wont affect the injectors much and how much power your looking at.
because it shoots the extra fuel in with the spray whereas a dry shot depends still on the regular fuel system, Good luck man hope it makes some good power didnt mean to scare you about the injectors i was just thinking if you wanted more power later on down the road bigger injectors will be a priority.
DOHCfiend
Apr 11, 2007 12:13 PM
Kturner
Sep 25, 2006 08:38 AM
