The Perfect Build
Old Feb 3, 2007 | 02:44 AM
WhiteRabbit1021's Avatar
Default RE: The Perfect Build
I'm still doing my own research but... do any of the turbo D guys want to throw in some information to help me out?
Old Feb 3, 2007 | 10:11 AM
It is a y8 right? If so, buy yourself a brand new oil pump, and I can hook you up with a link for modifying it to flow properly. Then you can just pull the stock one out of your motor, and slide the new one in.
Another good tip, although a bit time consuming, is swapping to a z6 head. Yes, the y8 flows better, but the z6 is much easier to work with when it comes to tuning. The timing on the y8 is annoying to say the least..
Old Feb 3, 2007 | 04:15 PM
cbaber's Avatar
If you want to run more boost on a D16 you need to buy aftermarket rods. Everyone always talks about snapping a rod so that would be the first thing. Maybe pistons? I dont really know other than rods. And you made a good choice by sticking with the D. Who needs 2 cams?
Old Feb 3, 2007 | 04:40 PM
hondad16's Avatar
for internal get piston, rods and valves, and get the head prted and polished. another good thing to invest in would be an aluminum radiator. aslo get new oil pump, water pump, andthermistate
Old Feb 3, 2007 | 05:21 PM
johnny's Avatar
Lots of these things are great ideas. Just he probly wont be able to afford all this stuff soon... Wel i dont know that for sure. Im waiting for Sov to come in here with a master list.
Old Feb 3, 2007 | 10:56 PM
SovXietday's Avatar
ORIGINAL: WhiteRabbit1021
I'm pretty new to the way a turbo works and what I need to do to beef up my engine. What other things do I need to AND/OR can do to "prep" my D for turbo?
Get some ARP head studs for the Y8. Building the engine only depends on how much power you want, if it's over 250 I would suggest putting in rods and pistons. You've pretty much got what you need to have some fun though.
Old Feb 3, 2007 | 11:06 PM
Pete's Avatar
Honestly, this is what id get if I were boosting a D again.
Custom turbo setup. 550CC injectors, walbro 255lph, ARP Headstuds, koyo or another reputable radiator, and a professional tune by a well known tuner. If you tune for 185 whp your car will be so much faster than it currently is, and youre completly in the safe zone as far as engine strain goes (Assuming you really got a good tuner) Like forty said, the y8 head can give you tuning issues, but if you go to the right tuner and they chip your ecu with a great program, youll be fine.
Old Feb 4, 2007 | 12:55 AM
ScoobyAddict14's Avatar
formerly aryiman98civic
the link that you have for the greddy kit is for a si. you want to look for one for the d series motor.
Old Feb 4, 2007 | 03:35 AM
ORIGINAL: aryiman98civic
Hmph... I posted the wrong link I guess. Anyways, I won't be doing the kit anymore. I'm going custom. I'm puting 5k into this so far.
Old Feb 4, 2007 | 09:58 AM
that is good that your building your own kit. i would recommend people did that instead of buying a kit.
turbo speeder
Jan 28, 2009 03:57 PM
Civic|UnLimiteD
Feb 18, 2007 04:46 PM
SovXietday
Feb 12, 2007 11:55 PM
carlover
Aug 6, 2005 07:59 PM
voz
May 23, 2005 02:38 AM
