Is it possible??
Old Dec 8, 2005 | 11:15 PM
civicboy01's Avatar
Default Is it possible??
Is it possible to Super-charge and Turbo-charge an engine?
Kappa22's Avatar
Default RE: Is it possible??
Yes. It's called twin-charging. You can even run twin turbos and a SC if you're crazy enough,
Old Dec 8, 2005 | 11:30 PM
civicboy01's Avatar
[sm=badbadbad.gif]
I'm on a ****ty/annoying computer, so I won't do it now, but I wrote a list up of all my mod's and prices, and basically I will have enough to play around alil bit with the engine.
I was thinking the Super-charger would help with low end power, and a Turbo-charger would help with high end power. I was gonna re-build most of the motor to run major boost(15 psi on turbo/new to super's)
Any ideas on what I need to 're-build' on the engine? or I think I heard some guys even talking about boring the engine also.
Old Dec 9, 2005 | 01:42 AM
Marty's Avatar
Waist of money for one thing because a properly designed turbo setup will do everything twin charging will do, 2nd thing a pain in the rear/tuning nightmare and that is if you can even find a shop that will touch anything like that. I will dig up some info on this and place it in a F.A.Q. type thread for you guys.
Old Dec 9, 2005 | 09:00 PM
civicboy01's Avatar
thanks alot man, I work at a plumbing, and alot of other things biz, and the owner owns a vette, a c6 and one of the workers got a cobra, and we were all talking today, and I just want more horsepower, a i/h/e just won't cut it for me
Old Dec 9, 2005 | 11:05 PM
Nail I3unny's Avatar
the thing about twin charging is you have boost down low from teh SC, then your car is on crazy pills when the turbo spools up and you're twin charging.
i think it was forty who said this, theres someone around that he knows about who has a big turbo that runs like 20psi all day, and to not have to spool up he has nitrous set up to spray until the turbo spools up, then it shuts off when he reaches his set boost level. in other words, running 20psi with no turbo lag.
Old Dec 10, 2005 | 03:03 AM
Marty's Avatar
Here is my true stance on it.
Can it be done? Yes
Is it worth it? No
I will find some stuff on it in the morning for you guys to soak up.
*edit*
Read this
http://smuggletrain.com/tc.html
Old Dec 10, 2005 | 09:57 AM
StifflersMom's Avatar
Cat Fuсker
possible, but you won;t be able to use a Jrsc for it...
Old Dec 10, 2005 | 10:40 AM
ngoti 8tor's Avatar
ORIGINAL: Kolhoznik
Why not Jackson, can you elaborate?
Old Dec 10, 2005 | 10:52 AM
Cat Fuсker
IMO you'd be better off with a SC that is not an integral part of the IM.
