Boosting a stock D16Z6?
Old 06-22-2007, 07:57 AM
Lost's Avatar
Default Boosting a stock D16Z6?
I wanna boost my bone stock Z6 at 8psi but its got 256,000 kms on it. You think that the high kms on the engine will push a failure? Should I not bother?
Old 06-22-2007, 08:22 AM
Default RE: Boosting a stock D16Z6?
Use the search bro..
Compression and leakdown tests are required for higher mileage motors. Get those done, and go from there.
Or if you have a second mode of transportation, and don't give a **** about the motor in there, just boost it. If it blows it blows right? z6's are like $300
Old 06-25-2007, 05:37 PM
didder's Avatar
do the compression test, 10% between the 4 cylinders. if youve got that then boost away. andits a honda, you can run it for a million miles if you want if you take care of her. and like forty said, if she blows, drop a $300 z6 in it. someone you know has to have a spare car for a week
apparently i just learned that torque kills engines, so go with a big turbo that puts out lots of hp with not so lots of torque. if anything goes wrong its probably gonna be a snapped connecting rod. has the car been pounded on its whole life or been treated nicely. that makes a difference too, my buddies celica gsr through a rod and his motor is basically stock with only 90k on it,just cuz he beats the **** out of his car.
Old 06-27-2007, 07:21 AM
Lost's Avatar
Ill run a comp check tonight.
The car has been driven nicely untill I got it a week ago, I drive her hard but have only got up to VTEC maybe 3 times, I shift at 4k rpm every time cause im scared of the high kms on it.
I was thinking of getting a T25 for now while its a stock plant.
But Im collecting parts to build up the engine, ARP's, Valves and springs, Gaksets, Pistons and rods, rings/bearings, hone, clearance checks and then Ill upgrade the turbo to a GT28RS. Of course ill upgrade the fuel system also, and maybe new axles and an LSD.
Old 06-27-2007, 05:00 PM
johnny's Avatar
Cars are like people. A Person can die at 60 years old from being an alcoholic and a chain smoker. A person can live to be 90. it's all about how you treat your car. My brothers old cavvy pretty much crapped out at 150kms. get yourself a compression test and whatnot, and see if your cars eligable. i think it would be better to get another block, and build it up. FOr 300 you can't go wrong, and you can get one with alot less kms.
Old 06-27-2007, 05:36 PM
Lost's Avatar
True, but the only way Id do that is if I find surface warpage. However, it would be nice to add things to a block on a stand and not have to stress about doing the whole project over a weekend, so we'll see.
Old 06-27-2007, 06:08 PM
johnny's Avatar
Sov had a D16y8, and he kept it in his car and built a D16z6, it gave him enough time to do all the work, so you should look into it. But yea, You can't exactly expect things to all work out in a weekend, cause it could take weeks, if something doesn't exactly go as planned.
Old 06-29-2007, 02:43 PM
civicorbin's Avatar
hey if it blows get it on camera id like to see
Old 06-29-2007, 04:35 PM
Lost's Avatar
^Not gunna happen. Im not gunna just waste my engine like that.
Old 07-07-2014, 03:59 AM
Gigorga's Avatar
I made an account for the sole purpose to reply to this, my D15 has 550,000 kms+ aswell with the original transmission and she barely burns oil and I'm revving past 4k rpm even to 6, and I beat on this motor day in and day out.. All my hondas are well pass 400,000km all with their original non rebuilt motors / transmissions.. I don't see why or how your worried about a low km motor.. Unless it's mistreated it shouldn't be going anytime near that low number.
zero12
13
04-11-2006 10:47 AM
deadphishy
02-26-2006 05:09 PM
carboncivic
11-30-2005 12:22 AM
schweigel
10-17-2005 10:33 PM
rzimmer11
03-19-2005 11:18 PM
Quick Reply: Boosting a stock D16Z6?
