Quick Fuel injector question!
Old Mar 26, 2010 | 07:53 PM
XDeath's Avatar
Default Quick Fuel injector question!
i have a 96 civic ex and a turbonetics t3/04b kit, my goal is 350hp at most. My last part of the kit that i need are fuel injectors and i wanna knw if this is a good deal and how to check if these injectors are good/bad.
Heres the classified add of them: http://sfbay.craigslist.org/sby/pts/1661834270.html
Is this too good to be true? and also is this a good size for my hp needs?
Old Mar 26, 2010 | 08:23 PM
Are you building the engine?
Old Mar 28, 2010 | 11:53 AM
XDeath's Avatar
yea, i got eagle rods and vitara pistons. just wanna know if these 550cc denso injectors are what i need for about 350 hp, and how couldi tell if theyre really 550cc, good, or even saturated.. Also, since i have a 96 civic, would i need a resistor box if i install saturated injectors??
Old Mar 28, 2010 | 12:06 PM
OEM are saturated (high impedance) injectors, so you wouldn't need a resistor box. Low impedance injectors require a resistor box.
Check this out, lots of great information
http://www.rceng.com/technical.aspx?...CBzCphVfYDzP8P
make sure you get a high-flow fuel pump too (walbro 255lph)
550cc should be perfect for your goal I think. Here's some research I did on it:
http://www.honda-tech.com/showthread.php?t=2678081
Old Mar 28, 2010 | 12:27 PM
Brock_10's Avatar
Yeah 550cc would work great. But like trustdestruction said, make sure you get a new fuel pump and also a high flow fuel rail would help.
THE_CRIPPLER
Dec 6, 2005 08:26 AM
sacicons
Aug 23, 2005 08:24 PM
Street Sniper
Aug 7, 2005 03:47 PM
fast93civic
Apr 11, 2005 05:34 PM
tominrm
Apr 10, 2005 08:23 AM
