threw a rod!
yea, i did not look at the internals the engine only had 96k on it. it also was spraying anti freeze all over through the over fill resevoir...the shop said it was from running low oil and over a period of time it ruined the bearings cauzing the rod to be distroyed.
no i did not have that gauge. but i think that just from over time having run low oil and the head gasket going bad that when added boost made this happen quicker. do you guys think a bad tune could of made this happen?
sounds like a bad tune.
low oil sounds like a possibility, but i really don't know. if that was the case i'd think you would have noticed the rod knock before you threw the rod through the front of the block.
you put more oil in than usual right? when you're turbo'd you need a little more oil because of the turbo/oil lines.
