Turbo b16 setup
That is up on the list of top 10 most vaguest questions ever. What are you going to use the car for? How much hp are you looking for? Do you have another mode of transportation? How much work are you planing on doing yourself?
ORIGINAL: kosarka
i am looking for somewhere around 300 horsepower.......
ORIGINAL: Mr Mobsta Man
Your going to have to rebuild your engine if you want more than 250 from you B16.
a t-3/t-04E is a good starters turbo IMO with a set of DSM injectors and a resistor box (cheapest way) then you could go the more expensive way and go with RC or other brand name bigger injectors than stock. but at the same time you'll need a way to control those injectors, IE: a VAFC2 (cheapest), or some form of a standalone, IE hondata,chrome,uberdata, so on and so forth.
so my biggest question is, how much do you want to spend?
You know what it might also be wise of you to change the head bolts just because boost pushes up on the head it will save you a headache down the road and you do realize that you just dont need turbo you need injectors,resistorbox,etc and to boot! WITH THESE ****ING GAS PRICES YOU CAN ONLY RUN 91!
ORIGINAL: MY99SI
False. 10-12 psi on a good tune will net more than 250 whp more like 275-300ish with a good tune.
Mistaashby12
15
Jul 16, 2008 11:30 PM
johnwohl
Jan 9, 2008 07:34 PM
rdas45
42
Apr 13, 2007 01:52 PM
