Turbo Diagram???
Alright,
I am trying to install a turbo on an '88 civic, with a JDM 16Z. or at least that is what my boss said it was, I have not seen the car yet, I have seen the JDM turbo kit that he wants me to put in though... He got it off of e-bay and it has NO installation instructions... I cannot find any online... Can some one Please send me a Diagram for this turbo? I believe it is a T3, I specifically need the Vacuum Diagram for the boost controller... Thanks, Rouy_Daed |
How much boost are you gonna run? If you are running the minimum boost just run a vacuum line directly to the wastegate no need to have a boost controller. FYI ebay turbo kits suck. Every kit i have seen you end buying various parts to complete it.
Like I said, I didn't buy it.
The customer buys the stuff, We install it... and we are going to be running mid level boost, probably 8psi, 10 psi, maybe even 12psi. It all depends on what the dyno, and computer tell us after install... But I Still need the vacuum Diagrams...so some one PLEASE post a link to some... |
well its going to be your prob when you get sh^tty results and don't have everything you need....what are you using for tuning or are you using a piggy back and did it come with bigger injectors etc....u shoultdnt go over 8psi if its stock
all you had to do is search http://images.search.yahoo.com/searc...p=mss&ei=UTF-8 |
No need to get hateful. Its hard answer your question without all the information.
lol you get what you pay for
In this case scrap metal! ;)
I don't understand how you are having difficulty hooking up a boost controller. It goes on the vacuum line that runs from your vacuum source to the wastegate. It's simple.
If that doesn't help you for some reason, then you need to show us what boost controller it is so we can help you. |
