turbo kits
for all you civic owners that have turbo kits or have great knowlage of turbo kits i have a question its for a 99 civic ex and i have been looking around for turbo kits and the two kits that seem to be good kits is drag turbo kit for horsepowerfreaks.com i will give the link if you guys want to check it out and the Edelbrock kit so please help.
to look at the drag turbo kit go to http://horsepowerfreaks.com/ and click honda "select" then civic select then go to turbo kits and you will see it there let me know what any knowlageble turbo buff thinks?
Drag Turbo Turbo Kits
Generation 3
Kits come complete with the following:
Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T4/T3 High flow turbocharger assembly
Turbonetics Deltagate Mark II Wastegate (7 PSI Spring)
Drag High Flow front mount intercooler w/polished cast aluminum end tanks
BLITZ Super Blow Off Valve
Drag mandrel bent high flow chrome plated intercooler pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegaste dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Drag Boost dependent FMU fuel regulator
Intake air filter assembly
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All necessary hardware and fittings
All necessary hose and hose clamps
All necessary gaskets
Installation manual
now that sounds pretty extencive to me
Generation 3
Oil return assembly
Installation manual
